![]() | Home > Maintenance & Mods (L322) > Air suspension and canbus fault |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2261 ![]() ![]() ![]() |
Date: 01/31/17 20:31:57
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
I'm having a similar problem! Have you tried erasing faults from the steering angle sensor and abs modules then doing the steering wheel full lock left to right? |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
I guess not by his no reply .
Hi sorry moved to another thread as it looks like the steering angle sensor is the culprit - will be changing this weekend hopefully Current stable:
Just changed sensor mechanism - cleared faults and we are good
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 ![]() ![]() ![]() |
Bumping this old tread instead of opening a new one.
Tough one I can’t remember if I couldn’t read the abs or not but the SAS fault is more and more common i on so probably 5 people in the last year or so who’ve had it where as I didn’t know anyone before I think their age is showing... Current stable:
Found water in the plug of the ABS pump under the bonnet. The plug has already taken one pin of the ABS unit so I'm looking at a new (used) ABS pump and a new plug.
