Home > Technical (L322) > Td6 injectors
Coconut
United Kingdom 2003 Range Rover HSE Td6 Barolo Black
Td6 injectors
Hi
Had a starting issue and ending up replacing the fuel pump and injectors on an 03 td6.
This cured the starting issue however the engine especially around 2k rpm under load makes what I can only describe as a pinking / tappet noise.
Do the injectors need programing?
The new high pressure fuel pump is quite noisy don't know if this is relevant.
Any advice would be greatly appreciated.
Thanks
Mark
Post #461596 21st Dec 2017 2:11am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
The injectors do not need programming. The high-pressure pump at the front left of the engine should not make any discernable noise above the normal engine level 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #461598 21st Dec 2017 2:54am
wayneg
Who swapped the injectors? Are you sure all the old washers came out, all new washers or at least old washers went back in after ensuring the locating holes were clean and free of carbon? Are all the clamps the right way round? 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #461600 21st Dec 2017 5:08am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
im with wayneg on this , if there was no noise before then there shouldn't be one now pal , id start looking incase you do some real damage by driving it
Post #461625 21st Dec 2017 2:10pm
Coconut
Thanks for the update
A local mechanic swapped them out and he has always been good.
It’s the pump at the rear of the car that makes the noise could it be an overfueling issue?
Post #461677 21st Dec 2017 7:21pm
Might be worth having him recheck his work sir... Get the timing checked as this too will make it pink/rattle
Post #461679 21st Dec 2017 7:33pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Even reputable mechanics can make mistakes sometimes....Have him check the work he's done. Agree with bembo; don't drive it this way.
Noise from a pump is mainly because it's not hang-up well in rubbers. Fuellines which touch the body can cause the noise as well.
Good luck! Thumbs Up
Post #461767 22nd Dec 2017 8:09am
Coconut
Thank you all will have him re check things
Merry Christmas
Post #461819 22nd Dec 2017 3:32pm
Paul thornton
Are you sure it's not normal?
The td6 definitely sounds like a diesel whilst under load at low rpm but seems to get quieter once it gets moving.
Be interesting to see what your mechanic says anyway.
Post #462194 26th Dec 2017 2:33am
Coconut
Had a quick look myself the other day.
One of the injectors seems to be faulty as it does not pulse on idle like the others.
Just need to find out if it is the injector or a faulty loom as this seems to be a common problem!
Post #462195 26th Dec 2017 3:02am
