![]() | Home > Maintenance & Mods (L322) > Wiper arms into Service Mode? |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 712 ![]() ![]() ![]() |
Not sure about the RR, but usually achievable by turning on the ignition & wipers then turning off the ignition just before the wipers get to the top of their sweep. Paul,
akk Member Since: 21 Dec 2017 Location: Staffs Posts: 6 ![]() ![]() |
Tried that... it's a push button start stop and despite numerous timing attempts, (ala tipping point!) it's failed... engine goes off and wipers still return to the bottom |
Aagh - the perils of so little driver control with newer models !
Indeed |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
surely it cant be much of a problem to clean the wipers in their normal position? ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
[Edit - this applies to the L405 - it was posted in the L405 section & I just noticed the original post says L322 |
theres no winter mode on the L322 alistair...
Not much of a problem?
a stool or small step ladder ?
haha... I've tried everything... the blade just doesn't come far enough away from the screen to clean... like I said... 2 thirds of it is pretty impossible...
the wiper arm does come away enough to clean it...
I bet you haven’t tried removing them?
lol... I did think about removing it... but was convinced it was a sledgehammer to crack a nut! |
