![]() | Home > Maintenance & Mods (L322) > Re-Map???? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35704 ![]() ![]() |
that tyre change shouldnt have effected any thing ..check your hoses ... - .- -.
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 193 ![]() ![]() ![]() |
Cheers Stan I’ve found the leaks guess they could just be age related, was just concerned that everything was working harder since the change and if I should address it |
sorry , i meant your turbo hoses, they tend to get splits ... ... - .- -.
Would they only affect the MPG? |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
There's a thread somewhere on here where somebody had changed their tyres from 255 50 to 255 55 and was having similar issues. |
a loss of 8 mpg shouldn't happen..coincidence, but i reckon it's the turbo hoses.. ... - .- -.
There was a chap on here who was saying that when he switched to 255 55 tyres on his supercharged it rarely ever went into top gear afterwards hence had a similar drop in fuel economy.
Page 2....
he says its holding gears and not going into 6th but i thought that was all related to the engine rpm..even at a steady 50mph the auto box should go into top gear .. ... - .- -.
Putting on bigger tyres simply ups the gearing and as you can see by the photo that chap has posted, brand new 55's are a lot taller than worn out 50's
this is all beyond my knowledge level but i thought that even at low speed [50mph?] the auto box should go into its highest gear.. ... - .- -.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
going from a 40 to a 55 in tyre wall height will most definitely effect the speedo reading pal , you can get away with 5 either way without it effecting it but going 15 will defo upset it , as for the MPG thing , reckon its mechanical as the others have already suggested |
andy's '40' profile is wrong for the FF anyway, it should be '45'...... ... - .- -.
oh right |
