![]() | Home > Maintenance & Mods (L322) > Dimming dash? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35737 ![]() ![]() |
i'd check the alternator and make sure its a steady and not a fluctuating output.. ... - .- -.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 832 ![]() ![]() |
Maybe because the fuel gauge shows empty... |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2236 ![]() ![]() ![]() |
It lives on empty lol it’s on gas that’s why - no need to carry excess weight |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Mine dims a bit with lights and fog lights on at idle. Still charging OK. As for running with less than 1/4 tank it stresses the fuel pump and causes it to run hotter and shortens its life. Just keep the extra 38 lbs in the tank and leave the spare tire home. |
Does it still steer the fuel pump on lpg? Current stable:
Also notice I can do this on demand by turning both windscreen heaters on at the same time with the headlights on Current stable:
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
My 04,was doing that today when my battery terminal was a little loose and battery was down on charge |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
That would indicate that you should start saving for an alternator as it's getting a bit tired ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
If I’m honest it’s done that just never mentioned for about 18mths since I had it... if it had a cheap alt replacement could this do it? Current stable:
Possibly, if it's working then don't fix!! Yesterday I couldn't spell Engineer... Today I are one!
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1497 ![]() ![]() |
At idle, alternators generally only just manage to provide sufficient power due to the low rpm. They have a curved output Vs rpm graph which rises quickly and then flattens off. At low rpm such as idle the alt will be right in that steep curve section where the difference of a few hundred rpm could make a difference of 10's of amps.
hi all - read the voltage finally - although typically it ant very dimmy today maybe didn't notice as much as its light. Anyway battery when off 12.1 volts when on and running for a couple of minutes 14.2-14.3 volts fairly consistent thought the range... Current stable:
