![]() | Home > Technical (L322) > wierd non start after a 35 mile journey |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7979 ![]() ![]() ![]() |
I’d go for.....fuel pump under the passenger side sill starting to fail...... mine did it without any warning..... might be wrong.... 2011 Range Rover Vogue SE 4.4 TDV8
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
he was parked facing uphill and tilting toward the drivers side as I was half on the path , I rolled him back onto the level and he fired up within 4 spins which is about normal for him but come to think of it , every once in while he takes a little longer to fire , usually when hot , can I change this pump reasonably easily , as in im going darn sarf ( 4 hour drive ) next week so will get a new pump and take it with me |
Here was my thread at the time.... mine refused to start at all after....no fuel to engine....
thanks pal , that's a big help , cars only done 130k so id be surprised if it wasn't the original pump |
