![]() | Home > Maintenance & Mods (L322) > Wiper arms into Service Mode? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
if you can't clean your wiper as per my pic ,then you must be a premiership footballer |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 ![]() ![]() ![]() |
VW Golf Mark 5 onwards, and clones I presume, such as Seat, have an upright park procedure, but that is because the wiper arm fouls the rear of the bonnet if manually lifted upwards from the normal park position. |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
JLR dealer wouldn't do this - they'd fit new wipers and motor at JLR genuine prices and £ Oddles per hour labour. And do the back as well, just in case... ![]() |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
On both my TT and my FF, I manually move the arms to the deisired position for cleaning and fitting new blades. Then push them back into rest position when I have finished. I guess someone will tell me this is wrong. |
I wouldn't say it's wrong, I'd say it's brave! |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Have I missed something here |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Complex subject matter.... There is nothing that can't be fixed with a hammer😜😜
what hasnt been discussed is which way the wiper should be wiped, left to right or right to left..... ... - .- -.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Before you get down to that level of detail Stan surely one must decide if you start with the passenger or drivers side. Also what about left hand drives models ?? Do you reverse the procedures?? 2015 4.4 AB
valid point |
And if one is Left Handed or Right Handed |
