![]() | Home > General > 2007 vogue at a good price? |
| Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89
Looks like a reasonable example. Ignore the sellers hype, it's not "fully loaded". The missing "Logic 7" badges on the speaker grill has me doubting if it's the Harmen Kardon premium system. That said, the important stuff is on the Vogue spec anyway. Make sure EVERYTHING works. If it has a button, expect it to function. Pay particular attention to the turbos (no bad noises, no rattles or lack of pull) as they're £3,500 to sort. Make sure the gearbox works smoothly, and ask when the gearbox, transfer box and diff oil were last changed. If they look confused assume never and make that one of your first jobs if you buy it. Make sure the ride height raises and lowers from the switch in the center console. Air struts and pump are another expensive thing that can wrong. Check the DVD Nav operation if it has it. The roof aerial can become ingressed by water and stop receiving GPS signals leading to an inaccurate positional representation on the screen.
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424
Looks to me as though the drivers seat bolster is all the way through at 1 point. A dot which is yellow i.e. the colour of the seat foam.
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836
i cant find it using that no ??? RR 2005 4.4 petrol
| TDSIX Member Since: 19 Feb 2017 Location: Stirlingshire Posts: 210
As noted above, I reckon that is a spot of water with the interior light reflecting off it... |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
Did you buy it then? |
| Mr.plow Member Since: 03 Sep 2017 Location: the middle Posts: 4
I've recently purchased similar. Best to budget for something unexpected to happen. Two front struts within 6 weeks! |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
it is keenly priced when looking around the market at similar cars , id HPI it , its been detailed to death , waaaaay to shiney for a car of that year and mileage imo |
