![]() | Home > Technical (L322) > TD6 Intermittent judder / injector fault |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
You could treat yourself to one of these kits if you have more issues..https://www.ebay.co.uk/itm/BMW-335-D-Brass...SwKrhVbXHL 2007 TDV8 VSE
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Brass connectors look fancy but I'm hoping that I've seen the back of it!
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
I've fitted those brass injector bleeds as i got fed up with the plastic rubbish breaking / leaking, well worth the investment.... I've got them on my Merc too |
Miggit, I totally agree, they all go brittle along with the hose degrading so it's only a matter of time. 2007 TDV8 VSE
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Great post Paul, really helpful.
Hi Paul,
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Using Faultmate mine reads all zeros when I rev the engine.
That means all the injectors are ok then.
Thanks for the feedback Paul.
If it is injectors at fault you should get other faults logged as the EMS tries to balance out the cylinders.
Thinking about it, I just took all my injectors out and sent them to a Bosch agent to have them cleaned and tested, 2 failed and needed new guts, after the engine was the smoothest I'd ever known it.... If you car has done 80k+ then a complete clean of the injectors will give it another 80k's worth of life... And I had mine done at 110k, just after it all failed 200 miles away from home with a 3 ton trailer in tow |
I agree, and tbh how much difference its made to mine just replacing one injector, I'm thinking about removing the other 5 and getting them tested / cleaned.
