Home > Maintenance & Mods (L405) > Thule Easybase - a recommendation
Due to the inability to put roof bars on an L405 without permanent rails, I bought one of these to put extra luggage on the back.
The car was absolutely packed and I ended up with over 100kg on the rack - even though it is only rated for 45kg, it didn't move in over 800 miles of fairly brisk progress and a mix of roads,
It did attract a bit of dirt though, so I was glad I decided to use pallet wrap on the bags - which I was able to just cut off when we arrived and carry clean bags up to the appartment Thumbs Up
Post #421442 6th Jan 2017 4:01pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I'd love to be able to use one of those, but need access to the boot on journeys (see signature Wink ). I take it that the luggage rack doesn't have some miraculous "swing out facility" to make this possible? (I'm clutching at straws here! Rolling Eyes )
Post #462241 26th Dec 2017 7:18pm
Unfortunately not, but the way I loaded it with just 2 big bags would mean you could unload fairly quickly. If I’d kept it, I’d have adjusted the back piece to be a bit shorter, so only top bag needed removing to open the upper tailgate.
Having an ice hockey goalie in the family meant that we had some suitably large bags Thumbs Up
I took a bit more stuff this year Whistle
Post #462243 26th Dec 2017 7:29pm
That beats a roof box. A little extreme though, but I bet the car was comfier than when you posted pics of it stuffed with snowboards. There is nothing that can't be fixed with a hammer😜😜
Post #462248 26th Dec 2017 7:55pm
The trailer was pretty full - but towed a dream - I was glad it was a warm, dry day when we arrived and no snow on the roads though Thumbs Up
Post #462252 26th Dec 2017 8:08pm
Why not buy something like this? Im sure there are far bigger/better ones available to the european markets...
https://www.ebay.co.uk/itm/thule-easybase-...0005.m1851
Post #462255 26th Dec 2017 8:51pm
Red Merle
It's just down to not being able to open the tailgate once the rack is fitted and loaded.
Post #462256 26th Dec 2017 9:11pm
1strangerover2017
Never enough room!
I have the permenant rails, but am currently on the search of a larger box trailer, I have a smaller unbraked Ifor Williams, Alistair - looks like you have all bases covered!
Post #462260 26th Dec 2017 11:05pm
Singh911
I have an Atera Strada DL bike rack - it slides away from the car to allow the boot to open https://www.roofbox.co.uk/scripts/rbvehsel...5K%7BW%7D. We used it on the FFRR down to the alps last summer with 3 bikes it was perfect.
I;m wondering whether, with one bike on the rack, we could strap a large bag (say 250L) onto the empty part of the bike rack. We need to take our labrador with us and need therefore to access the boot during the journey down to the south of france.
i will give it a try and report back. The bag will not slot into the bike rack like the thule bags do onto the thule easybase but with some rachet straps one should be able to secure it properly?? something like these straps https://www.roofbox.co.uk/scripts/rbvehsel...ure%60i0A6 rated for very heavy weights Current
5.0 S/C 2010 Autobiography
458 Spider
996 GT3 mk1
GR Yaris
W124 E320 estate
Previous
VSE MY2016 3.0tdv6 - stolen January 2024
F10 M5
Cayenne S
993
X5
Post #467228 4th Feb 2018 12:34pm
Those straps are a bit OTT - the important thing is finding something to fix them to - and anything with a hook on it, can come unhooked more easily than you'd think, especially with a soft bag.
Something like these or thse might actually work better even though they are lower rated.
I used those and also a couple of these which i threaded back on themselves - you can probably see from the photo's above.
Trial & error, but any hook that can slide, will work its way loose......
Post #467278 4th Feb 2018 6:25pm
Bill
That looks like the biz niz , will allow the dog or the wife out of the back (depends who is behaving best) especially if it somehow takes a load of luggage. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #467333 4th Feb 2018 9:52pm
Sandyt
I have one of these - solid piece of kit https://www.roofbox.co.uk/scripts/rbvehsel...C4urewinks
Post #467338 4th Feb 2018 10:12pm
Singh911
Yes the Thule is a solid bit of kit. I looked at both that and the Atera I ended up buying.
The major factor for me was I wanted the best possible clearance and access to the boot when the bike carrier was in its slide away position. This I needed both for long distance trip and also (Icycle a lot) when going out cycling, I can slide the carrier away and sit on the split tailgate when open and change into cycling shoes etc.
Having seen both in the flesh, the Thule did not clear away as much as the Atera. Its legs were much m ore of an obstacle when slid away than the Atera too.
I would have preferred the Thule as I think it s an even more solid bit of kit than the Atera. Having used it to the alps and back, and lots over here within the UK, the atera is absolutely fine and crucially for me offers excellent access to the car when slid away.
HTH Current
458 Spider
996 GT3 mk1
GR Yaris
W124 E320 estate
Previous
F10 M5
Cayenne S
993
X5
Post #467623 7th Feb 2018 12:47am
RRTIM
United Kingdom 2017 Range Rover Vogue SE SDV8 Causeway Grey
This was ours with the back box fitted.
Since then I have substituted the rear upstand with 2 shorter 1" stainless pipes, which now allows me to open the upper part of the boot.[/img] 2017 Range Rover SDV8 Vogue SE
2018 Audi RS6
2018 VW Amarok V6 255
Post #468579 14th Feb 2018 1:59pm
mabanks
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Interesting thread, I’m in the same boat.
Singh911,
Whatwas the outcome of your experiments. I too need more space but don’t want roof rails, I have the Strada carrier already from D4 days but have yet to try on our new L405. Need to be able to carry one bike and our sons university stuff, how did you get on?
Also, on the D4 and with 4 bikes onboard I used to use webbing straps for additional support, these clipped over the top of the tailgate, something that the RR’ s tailgate spoiler gets in the way of. Did you find a workaround or not bother?
Thanks for your help.
MB 2007 Disco 3 HSE
2014 Disco 4 HSE
2018 L405 A/B SDV8
Post #509820 25th Mar 2019 7:07pm
