![]() | Home > Technical (L322) > TDV8 using / loosing coolant |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 ![]() ![]() ![]() |
Have the coolant system pressure tested. You can get it done in a garage or buy the kit your self for about £50.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
There is a pipe which runs from the bottom of the header tank, about 1/2in in diameter, it catches and rubs on the body/another pipe and can wear through. Easy enough to check and change, if you feel down the pipe you should feel where it’s been rubbing if it has and can see if there is a leak there.
Just noticed it has had the egr done, has it been bled properly? These are a real pig to bleed
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
I would be looking at the coolant piping and plastic thermostat in the 'V'..which can leak and the coolant will then evaporate so just the orange residue as evidence...until the leak gets worse anyway! Takes a while to get to the thermostat and pipes if that is the problem, so worth replacing the whole lot for peace of mind whilst you are in there. |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
My TDV8 started leaking from a hose on the RHS of the radiator. Took ages to find as only very small amount of leakage and would evaporate or get caught on the undertray so never anything on the ground. My leak was right below the jubilee clip attaching it to the radiator - pain of a job due to limited space, but half an inch of hose removed, reattached with a new jubilee clip and was fine. Good luck finding your leak! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
mattyboy Member Since: 14 Feb 2012 Location: Colchester Essex Posts: 28 ![]() ![]() ![]() |
quick re-cap, had a pressure test done yesterday and it's coming from the plastic thermostat housing, time to start stripping... |
Whilst you are in there, do the two small elbow pipes too for peace of mind! |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Had mine done 2 years ago and fine since cost me £270 all in including a lower arm aand air filter same time |
