Home > Technical (L405) > Tailgate only opens half way.
AndyS
My tailgate has now decided it only wants to open halfway up, previously it's been faultless. The bottom section opens fine. I checked on here but can't see much info so has anyone else had this issue and know the fix or am I heading for the dealer?
Any help appreciated.
Post #462411 28th Dec 2017 10:12am
Pixelpower
United Kingdom 2005 Range Rover Vogue Td6 Santorini Black
Mine did that, and still does occasionally. The first time the dealer sorted it out. Now it seems to reset itself after closing again. Maybe they updated the software.
Post #462413 28th Dec 2017 10:21am
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Hi does it always stop at the same point ? Is it possible you have programmed it to do so accidentlally by restricting it opening one time? Try pressing the button again when it stops until it is fully open then keep your finger on the button to store the new opennng height. Worth a try. I have had a couple of issues with mine but always the bottom section never the top. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #462416 28th Dec 2017 10:34am
AndyS
Yes, exactly the same about half way each time.I tried holding the button down and all it does is try and close,
Post #462433 28th Dec 2017 12:47pm
ADI
England 2016 Range Rover Vogue SDV8 Fuji White
I would try manually opening to full height as highlighted below
From the manual
TAILGATE OPENING HEIGHT
The maximum opening height for the tailgate can be set as required. Setting a maximum height is useful in parking areas with very low roofs, or just for ease of use.
To set the maximum opening height as required:
Open the tailgate to the position required as the maximum height. Press any opening or closing button to stop movement at the required position. The final position can be achieved manually, if required.
Make sure the tailgate is stationary for at least 3 seconds.
Press and hold the close button for 10 seconds to set the required opening height.
Press a close button to close the tailgate. Open again to check that it opens to the required height.
The maximum opening height is now set.
NOTES
If, after performing step 3, the tailgate closes automatically, the required height has not been set. Repeat the process, making sure that all steps are adhered to.
To reset the maximum opening height, repeat the process, but fully open the tailgate before pressing and holding the button.
The powered tailgate may lose its position memory if there are multiple object detections, or if the battery voltage is low. Powered operation may be inhibited.
To reset the tailgate's opening height:
Manually close the tailgate.
Press a release button.
Allow the tailgate to power fully open, or to the previously set position.
Press and release the close button.
Allow the tailgate to power-close fully.
The position memory is now restored.
Hope that helps
Andrew BMW X3 30e XDrive M Sport
GoneBMW 330e
Gone MY2016 RR Vogue Fuji White SDV8 with a few extras...
Gone MY2016 Discovery Sport HSE
Post #462454 28th Dec 2017 2:45pm
AndyS
Thanks Andrew, all restored to normal.
The moral is when you have an issue then RTFM Whistle
Post #462732 30th Dec 2017 5:04pm
