![]() | Home > Technical (L322) > 2007 4.2 sc gearbox issue 2-1 |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
Software update using an IID tool sorted my gearbox issues and is known to help the 2-1 thump issue. |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 615 ![]() ![]() ![]() |
Had a slight shunt on mine not very often. Just done oil and filter no update done all seems good |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Firstly,
Dano0404 Member Since: 28 Dec 2017 Location: Uk Posts: 44 ![]() ![]() |
Thanks mine is on 78k atm, shall see how I get on with the oil. Just been out for a test run and dose do it in manual if you catch it wrong the car can rev up like it’s in neutral before it selects 1st.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Mostly the gearboxes don’t want to select first,generally they will pull off in 2nd only picking 1st if you bang your foot on the gas. There is nothing that can't be fixed with a hammer😜😜
Edit |
Blair Member Since: 03 Apr 2017 Location: Suffolk Posts: 72 ![]() ![]() ![]() |
My 2007 4.2SC has a distinct slight shunt in the transmission, particularly when changing from deceleration to acceleration at very slow speeds. It's not a big clonk, just a slight shunt you can feel. Like above, it also rolls slightly on taking up park. I suspect it's transfer box or diff related due to mileage and heavy city use prior to my ownership.
Changed the oil and the 2-1 knock has gone. The 3rd gear transmission fault was low voltage on the battery so changed that and all is good again. 2007 sc |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
Oil change sorted out a poor 2 to 1 shunt on mine too. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Mine is on 180k had it for 5 years and done 120k change the oil in my gearbox every 30 to 40 k no problems and mine rolls forward too always has |
