Home > Technical (L322) > Wont start even after changing the ignition switch
CS
Thanks, that was just me speculating, the starter motor has been changed now and all working again. They said "when we tested it, it was overheating very quickly". A neighbour with a 60 reg 4.4 TDV8 said his one had been replaced a while ago and that they were a known problem area, perhaps it is just poor quality components. Apparently JLR get the defective ones back for remanufacturing, as also compressors. Only Range Rovers since 1988
Post #462656 29th Dec 2017 7:05pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
stan wrote:
i did think that but it starts first time when its not below freezing, but i will keep your suggestion on file in me head.. Thumbs Up
I have had this on other vehicles where a small amount of water has got into the starter motor. It behaves fine normally but when below zero the water freezes enough to stop the motor working. Some times a couple of turns of the key will free it but if it's really cold it will be solid.
Post #462838 31st Dec 2017 10:34pm
that makes sense Thumbs Up ... - .- -.
Post #462850 1st Jan 2018 8:53am
@GDM, you've hit the nail on the head there....mine has in the past had the 'click' and no start but then during the recent cold 'dry' snap i've had no problem starting..
toady now the thaw is taking hold ,everything is wet and the click no start has come back suggesting water in the starter as you've reported.. ... - .- -.
Post #470849 3rd Mar 2018 3:33pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
As to battery choice.
This seems to be a common FFRR failure after 2 - 3 years, so I go with highest AH and CCA and a 5 year warranty.
If it fails again, I won't be paying for it... Very Happy
Post #470882 3rd Mar 2018 7:10pm
