![]() | Home > Maintenance & Mods (L322) > Daytime Running Lights |
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
It is here! (Nearly always 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
| Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608
Glad you sorted it |
| RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 43
I asked my dealer to enable the DRL's on my 2012 FFRR last year when they serviced the car. And they told me they couldn't do it. I'd really like them enabled on my car, as I want my lights to stay on 'automatic' instead of turning the DRL's on manually. '17 Range Rover 5.0 Supercharged AB (Sold) '16 Range Rover SDv8 AB (Sold) '15 Range Rover SDv8 Vogue (Sold) '13 Range Rover SDv8 Vogue (Sold) '12 Range Rover TDv8 (Sold) '10 Range Rover 5.0 Supercharged '03 BMW E39 M5 '01 BMW E46 M3 |
| GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670
It's simple to do with an IID Tool - it must be if even I can do it |
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
That's just what I did........enabled DRL's with the IID tool and leave the light switch on Auto.
Thanks for the replies guys.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
if you pay someone to do this mod then you might as well buy one....there is so much more you can do with it.. ... - .- -.
| Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55
does anyone know if the GAP IID BT TOOL is capable of this mod, thanks
| Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125
Yes Kevin - very easy with the IID tool. |
ok, thanks FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
I’d say everyone needs an IID Tool. duckworthparts (highly recommended) on this forum will get you one - at the best price I’ve found. Well worth every penny / cent |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
I did this with an IIDTool, fairy/halo lights are on all the time (what I wanted) other light functions just work normally. They aren't as bright as "proper" DRLs but I only wanted the look, I know this will be controversial but IMHO DRLs are at best a waste of time and at worst annoying anyway but thats just me, I'm sure the EU in its infinite wisdom can't be wrong. Obviously not as annoying as fog lights, front or rear, when its not foggy, which the idiot driver has the option of turning on or OFF. |
| rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569
Regarding use of DRL's. I used to be one of those who thought it mildly amusing to 'flash' at Volvo's back when the Swedes made DRL's a legal requiremenmt and they came over here fitted with them. Since then I've learned a hell of a lot about visibility issues relating to mobile equipment and I can tell you, pretty much ANYTHING that gets you seen quicker is worth using. If someone else sees you 1/10 sec earlier, that could be a nasty collision avoided. It's relevant where the sun shines as well! Drives:
| westminster 62 Member Since: 03 Oct 2017 Location: essex Posts: 20
I had my drl's activated recently and didn't like the fact that the tail lights come on as well, so iv'e had them deactivated.
| All times are GMT |
