Home > My Range Rover > range rover with problems
Page 3 of 18 <123 4 ... 161718>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
thanks guys
Post #442841 27th Jun 2017 11:41am
knares
I have started working on it at last.
Some time ago I took the bottom sump plate off and lot of bits of plastic fell out, some pieces half as big as my thumb.
I have watched a few videos about changing the timing chain.
I am finding doing this very slow as I am not sure if I am doing the right thing most of the time.
I am at the stage of taking the rocker covers off but I am reluctant to take them off while the plastic boxes which hold the wiring for the plugs are still in place as any dirt or rubbish hiding there will fall in to the motor.
A video I watched, the guy said (I think) just remove the five bolts that hold the fuel rail on and it will, with the black boxes, just lift up out of the way.
Well, on way ha ha RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #462276 27th Dec 2017 5:25am
knares
any advice on how to go about getting the dip stick out ?? RR 2005 4.4 petrol
Post #462571 29th Dec 2017 9:43am
kanikune
Finland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Normally you can just pull it off.
Did you manege to swap the guide rails?
Post #462623 29th Dec 2017 3:07pm
knares
i should have said dip stick tube, Apparently its held in with a nut or bolt, 9mm spanner but how do I get to it.
I haven’t got to the guides rails yet RR 2005 4.4 petrol
Post #462681 30th Dec 2017 12:23am
holidaychicken
Why do you want to take out the dipstick?
There is a small nut 8, 9 or 10 mm where the tube meets the sump which you can reach from underneath quite easily and two cam cover bolts hold it at the top.
I took mine right out and it was a total pain trying to get it back in as it has a couple of bends in it. It does bend out the way if you just remove the cam cover bolts or if you want it more out the way remove the small nut at the bottom but just don’t take it right out from the side of the engine bay. There is an o ring at the bottom where it fits into the sump.
Post #462683 30th Dec 2017 2:20am
knares
got it out thanks, aq bit of friendly Persuasion RR 2005 4.4 petrol
Post #462685 30th Dec 2017 4:29am
holidaychicken
I got mine out with a bit of friendly persuasion, it was getting it back in that was probably the hardest part of my timing chain and vanos rebuild Smile
Post #462694 30th Dec 2017 9:09am
knares
I was watching a video last week, the guy, at the end of the video said, you cant use Chinese cam timing tools because it will show up as a fault.
I had already bought my cam timing tool, but now when I look at it, I see it is not square.
I bought it from an Australian dealer but I am sure its made in china
Is it supposed to be square
I wondered if someone who has this tool would mind looking at there’s and let me know if there’s looks the same as mine
 RR 2005 4.4 petrol
Post #462767 31st Dec 2017 5:55am
knares
Looking at the timing chain guides on ebay, it looks like the left one is all plastic, anyone know if a metal based one is available RR 2005 4.4 petrol
Post #462771 31st Dec 2017 9:26am
holidaychicken
They are all aluminum backed plastic, i used febi bilstein ones in mine.
i think your cam locking blocks will be ok although you would expect general good machining practice would prevail and they would be square but china don't seem to have the same ideas of what is wrong or right when it comes to precision engineering.
This is how they will fit on your engine so check they square against the bottom face and the locating surface.
i like the look of these https://www.germanautosolutions.com/diy_te...ls_diy.php
i made some retaining blocks out of tubing and an old spark plug, not that i needed to, i just did.
Post #462794 31st Dec 2017 1:52pm
knares
i was wondering about how to retain them, but as you say you didnt need to, i wont wonder any more RR 2005 4.4 petrol
Post #463500 6th Jan 2018 12:08pm
holidaychicken
But i have to tell you now even though you don't need to know !
I was replicating the Landrover tool shown on the attached.
i had an old spark plug and took a length of mild steel tube and tapped it over the ceramic part of the old spark plug and tack welded it to the metal part of the plug and then took a length of studding and tapped that into the tube and tack welded that to the tube. the wooden blocks you can see and then i just used a nut and washer to hold the wooden block to the studding.
Must be the only part i didn't photograph. i screwed the spark plug into the spark plug hole carefully and i didn't over tighten the nut on the clamp.
i only made them as My project was running over a few days and didn't want the timing blocks to accidentally get dislodged and screw the timing.
Post #463507 6th Jan 2018 2:15pm
knares
i see, so they do have a retaning clamp
where did you get them pictures from RR 2005 4.4 petrol
Post #463513 6th Jan 2018 3:17pm
holidaychicken
They do but i don't think most people use them as they don't come with the cheap timing kits.
Pics are from Rave which is a must .
download here http://www.fullfatrr.com/wiki/Main_Page
Post #463514 6th Jan 2018 3:23pm
