Rear flexible brake hoses - failure | |
I've had a failure of rear brake hose today, dumping fluid on the drive. Luckily at home and no real harm done. This time on the left side. About 6 months ago, exactly the same failure on the same hose in the same place on the right. L322 2010 3.6 TDV8.
LH part number LR058025
RH part number LR058026
The failed part has two flexible lengths of hose with a piece of rigid (presumably steel) pipe at an approx 135 degree angle in the middle. Around the rigid section, there is a piece of rubber, which I think is designed to protect the steel pipe against rubbing. In both cases, fluid is leaking from the end of that rubber section nearest to the caliper. When I took the last one off, it was very weak at that point - clearly corroded through, though you couldn't see where because of the rubber covering.
In hindsight, when the RH went last summer, I should have replaced both. At least it was warm with lighter evenings then! As an added complication, the bleed nipple won't release. I just can't budge it. On the RH last summer, the nipple snapped off. On the LH today, it's just rounding off. I replaced the caliper on the RH then; I'll do the LH now.
The pipes do get the worst of all the muck etc. in behind the wheel, but I'm not clear whether the corrosion is from the outside of the pipe or the inside. I've had the car 18 months and not replaced the brake fluid in that time. Despite full main dealer service history from new until I got it, I can't see charges for replacing brake fluid in any of the invoices... That probably means the fluid is 7 years old and has collected moisture to a significant degree.
Have others had similar problems?
What's the collective wisdom about similar hoses at the front? (A simply visual inspection of little value - I did that before - so do I just replace and be done with it?).
Clearly, in hindsight I should have replaced both rears back in June. I'll now be adding brake fluid replacement to my 'jobs' list in case its 7 years old. Unless bleed nipples on the front calipers undo easily enough, that'll be another two calipers, which will make the job more expensive. At least if I do it before failure, I can wait a few days for delivery rather than needing to pay main-dealer prices for the convenience of instant availability.
 | Click image to enlarge | Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
