![]() | Home > Technical (L322) > Leak in Boot |
colinwebster Member Since: 19 Dec 2017 Location: Devon Posts: 43 ![]() ![]() ![]() |
HI All,
Thanks Dragon, I have the factory removable towbar.....Ill gives it a check buy seems to be coming from above that level????
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 834 ![]() ![]() ![]() |
I also had exactly the same problem - It was caused by the rubber seal around the boot, which had perished over time.
aja500; Thanks for your reply.
After muchos rain last night, the diagnosis is the tailgate seal....
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Try it, you've 2 chances!!
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Just been out to check mine expecting to find a pond in the wheel well but there isn't!
Yep, somebody else has probably spent countless hours pulling their hair out trying to fix it before my ownership! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Look closely at the upper tailgate rubber seal at the top corner on the passenger side. |
Ok so I’ve sealed it up now and so far so good. If this fails I’ll get a new seal but at least I found the problem. |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Glad you sorted it, it can be such a pita to find these leeks ..... (see what I did their) 😂
Scottish Humour |
