![]() | Home > Maintenance & Mods (L322) > Battery replacement on 2011 Supercharged |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Done mine more than once or twice L322 TD6 should be the same shut stuff down as per on here (Search it) and put bonnet to service position. Remove earth first and replace last, undo and remove clamp have someone hold all leads as clear as poss and lift with back straight of course |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
I think it depends on the battery, have a search on here as its been covered. From memory and I stand to be corrected, some models of 322, notably the 4.4tdv8 have a charging system which needs to be told that a new battery has been fitted. Its pretty easy to physically change it, but if it needs coding then its an IID tool or diagnostic job. There is nothing that can't be fixed with a hammer😜😜
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Dickie
Dickie Member Since: 14 Nov 2012 Location: Gloucestershire Posts: 71 ![]() ![]() |
Awesome help Mark, thanks very much. I've not got a IID tool though sadly so I may have to consign this one to a dealer/indi to do, although I'll certainly give Duckworth parts a shout (the came up trumps with discs and pads for my old L405) |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
Ever since I got my car it has given that warning so I contacted the guys at GAP who said ignore it. I have for two years, it has always started no problem but the battery can't cope with the doors being left open for long hence the interior lights on maybe its time to find and fit those LEDs I bought ages ago |
