Home > Maintenance & Mods (L405) > TDV6 Suspension improvements available?
OldDD
Isle Of Man 2017 Range Rover Vogue SE TDV6 Corris Grey
Took delivery of a new TDV6 in December and love everything about it apart from the wallowy ride. Is there an electronic module or kit that can be purchased that would reduce the wallowing and pitching on corners and offer a firmer/sportier ride?
I'm not trying to turn it into a Supercar or ("lower it") but do feel this to be a major let down in going with the TDV6 over the SDV8.
Anyone else agree??
Post #463146 3rd Jan 2018 5:04pm
wack61
Post #463166 3rd Jan 2018 7:02pm
OldDD
Possibly, but as the car is fitted with Air suspension that is electronically calibrated, perhaps there is a recalibration software that could be developed that would better suit the vehicle which could be activated in conjunction with "Sport" mode??
Post #463168 3rd Jan 2018 7:29pm
someone on the L322 part of the forum told how an iidtool can calibrate the active dynamics of the suspension (not the ride height)
do a search... ... - .- -.
Post #463174 3rd Jan 2018 8:07pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
this is interesting as I find the 322 is anything but wallowy considering its sheer bulk , does the 405 not have a sport button to firm up the ride or anything ?
Post #463179 3rd Jan 2018 8:24pm
here you go olddd, found the thread,
http://www.fullfatrr.com/forum/post461756.html#461756 ... - .- -.
Post #463189 3rd Jan 2018 8:41pm
GraemeS
Australia
If your L405 has Adaptive Dynamics (CVDs) fitted then try switching off dynamic stability control by holding the DSC button for 2 seconds. Whilst I have recalibrated the CVDs on my L322 using my IIDtool, I have found that switching off DSC stiffens the suspension significantly, particularly obvious when cornering. My L322's DSC is forced on whilst cruise control is in use, presumably as a safety feature.
Post #463190 3rd Jan 2018 8:42pm
OldDD
Hi Graeme
I have no clue as I am a total newbie to RR but will do some research. I will try switching off DSC first and see what happens. Does anyone have a microfiche showing the chassis differences between the TDV6 and SDV8?? Does the V8 just have the inclusion of Anti Roll Bars?
Post #463211 3rd Jan 2018 10:44pm
GraemeS
Australia
All L405 will have anti-roll bars but perhaps only the SDV8 has adaptive dynamics although I thought that it was standard across all models. The tell-tale sign for adaptive dynamics is a thin wire harness attached to the top of each front shock /damper. The rears will also have the wires if the fronts do. If no wires then it has standard shocks, not ecu-controlled, so DSC can't stiffen them.
Edit: The MY13 TDV6 uses a different front shock part number to the SDV8 but the price difference is minimal so both must have CVDs / adaptive dynamics. If MY13 had CVDs then I would expect all since would too, but perhaps not.
Post #463228 4th Jan 2018 7:04am
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
Tall cars tend to have a bit of a wallowy ride but the 405 improved this over the 322 but it’s still a big tall car and that can’t compete with gravity. The SDV8 only, rather than the V6 has the Adaptive Dynamics and IMHO it’s needed more on the bigger engined model to deal with the extra 200kg+ weight of the engine. I’ve currently got the SDV8 and think that it handles similarly to the V6. The V8 has the trick electronics and the V6 has the lighter front end which even things out a bit.
Most manufacturers are moving towards lower cars, just look at the new Lambo, which looks more like a grand tourer than an SUV.
I’d have thought your TDV6 would be fairly typical of the marque I’m afraid. No matter what you are told or read in the media, tall cars tend to wallow in the bends but then I’d prefer that every day to something that rides like a sports car and doesn’t enable you to see over a super-mini. Enjoy your car and I’m pretty sure that after you’ve adapted to it’s characterists you’ll love it as much as many of us do. Thumbs Up 2016 SDV8 Autobiography
And several others previously.
Post #463237 4th Jan 2018 10:02am
OldDD
Wise words indeed Basil and I chose the TDV6 over the SDV8 for the exact reason you state - The 200kg+ weight saving at the front made the 4.4 feel very front end heavy and less agile than the TDV6 when driving the same roads.
I did actually try Graeme's recommendation of disabling the DSC and on first impressions I think it does feel firmer and less wallowy but why DSC would be linked to the suspension stiffness is beyond me? A placebo perhaps, so more testing is required but for the record I'm not trying to turn this into a 2 ton + Sports car but find a firmer less wallowy setting which suits my driving style and the roads where I live. I am already smitten with the car but "if" I could find a solution to this it would be mega Smile!
Post #463293 4th Jan 2018 6:20pm
GraemeS
Australia
Setting DSC off can only change the damper setting of CVDs because CVDs are computer-controlled. That LR implemented a firming of the suspension whilst DSC is disabled is presumably to make the vehicle more stable when changing direction to counteract DSC being off to reduce the risk of the vehicle getting out of control.
Post #463318 4th Jan 2018 8:51pm
Lonfred
Spain 2017 Range Rover Vogue SDV8 Carpathian Grey
Hopefully the new ”Highway” mode and the 15mm decrease of suspension highness when speed more than 100km/h on MY18 will solve this issue.
Post #463345 4th Jan 2018 11:13pm
GraemeS
Australia
Lonfred, can you provide a link to the new suspension specs?
Post #463370 5th Jan 2018 1:09am
OldDD
Sounds like a simple recalibration of Software making it potentially available to earlier models.
Post #463390 5th Jan 2018 10:53am
