Home > Maintenance & Mods (L322) > Re-Map????
Page 3 of 4 <1234>
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Could you imagine!!!! Errrrrr actually we can’t we do it..... Censored
Post #463203 3rd Jan 2018 9:54pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Try this from another source.
Unlock the car,
jump in,
press the accelerator to the floor so it presses down the kickdown and keep it down
key in the ignition
turn the ignition to stage 2 ( all the dash lights up )
DONT START IT ... just leave it there whilst you have the pedal to the floor
wait a while ( 30seconds or longer i think )
ignition off
key out
pedal up.
Go have a cup of tea while it sorts itself out and then go for drive
Or see here
http://offroadrover.com/check-zf-6hp26-tra...ermometer/ 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #463224 4th Jan 2018 12:38am
Andyyav
Tried the process this morning, held the pedal down for approx 60 seconds then gave it 30 mins to sort itself, no difference so far.
I had the gearbox flushed last April time so would hope the Indy has carried out the other process on the link, I’ll give them a try anyway and report back!
Post #463245 4th Jan 2018 11:16am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
It won't be a bespoke map for £350, it will be a generic map for that sort of money.
I would see if you can fit a different set of wheels and tyres with the correct original tyres on to make sure that the new tyres are the cause.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #463246 4th Jan 2018 11:23am
Andyyav
The wheels I bought had fairly worn scorpion zeros 255/50/20s on I then changed to the 255/55/20 General Grabbers at3
Both tyre sizes have the loss of mpg and hanging in gear......
Post #463261 4th Jan 2018 1:37pm
zarnd
Have you had anyone look at the car and see if any fault codes are stored etc...? You could be wasting your money with a remap if there is a different problem that a remap wont cure.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #463262 4th Jan 2018 2:09pm
Andyyav
I’ve not had any dreaded bongs or warning lights, Good point tho, I’ll get it checked
Post #463275 4th Jan 2018 3:59pm
Grofus
So, to be clear. The car came with standard tyres on and you changed them to 275/40's. Now you have 255/55's on.
When did you try the standard tyres on to notice it hanging in gears. Confused Me confused.
Hanging gears aside, how do you find the Grabber AT3 as I'm thinking about fitting them. Mainly concerned with wet grip. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #463351 4th Jan 2018 11:24pm
Andyyav
When I bought it it had the 275/40/20s on and done 28mpg according to the OBC, I then bought a set of new to me alloys (originals needed refurb) with the ‘standard’ 255/50/20 scorpion zeros on which I then changed to 255/55/20 AT3s (they don’t make a 255/50/20 AT3)
As for the tyres they’re great! Quite and comfy on the road and grippy in the mud, No issues for me in the wet/snow
Post #463354 4th Jan 2018 11:48pm
Andyyav
I had to wait a few weeks for the AT3s so was on the 255/50s for a while which is when I noticed the differences, the 255/55s seem to make the hanging more noticeable
Post #463355 4th Jan 2018 11:55pm
Grofus
Ah, OK got it. So did you feel it was "hanging" on the standard size tyres as well. At what speed do you notice the "hanging" and is it just top gear or other gears too. I can't help thinking a gearbox reset may solve it. There is a big jump in rolling circumferance for the gearbox to adapt to. The easiest way is with a diagnostic tool. I can't see how an engine map would solve it. It uses engine rpm, engine load, road speed etc to select a gear. An engine and gearbox re-map would work or just a gearbox re-map. You also have your own mind to recalibrate too as the speedo is now reading 20% slower than with your original set up.
If it were mine, I'd do a gearbox reset and go from there. That way you would know what was needed. Keep us posted on developments and good luck. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #463377 5th Jan 2018 2:56am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Grofus wrote:
Have you tried resetting the gearbox ECU. They learn driving habits so a reset on the new tyres maybe worth a try.
Jumping in ...
... how do you reset the gearbox ECU?
I have an IID tool - not used yet as only arrived yesterday - and have just switched to 22” wheels from 20”. What do I put here then?
Post #463383 5th Jan 2018 9:37am
Andyyav
Small Update-
Had some time Friday so thought I’d inspect the lower turbo hoses, only had time to do the drivers side, all looked well no splits cracks etc some oily muck on the inside of the hoses but didn’t seem bad to my eneducated eye, I did however notice that the hose and turbo ‘area’ appeared to be covered in oily gunk any ideas where this would be leaking from? Could it be related to my issues? I’m hoping to get the passengers side off in the morning to compare I’ve attempted to attach a photo of the gunk, the hose connection is the clean bit
@GAC23 see the link on Grofus post above
Post #463546 6th Jan 2018 9:54pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Check all the hoses which would be under pressure, If the split is a small one, the oil will only be coming out when you're on boost. When i had a turbo hose go on my Jaguar, it was the Turbo to Inter-cooler hose, and it split on the engine side, so i couldn't see the split, only feel it when i put my hand round the back.
Post #463640 7th Jan 2018 3:59pm
Vogue
They will as you have slightly over geared it - the 55 profile are larger in diameter = increase in gearing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #463648 7th Jan 2018 5:04pm
Page 3 of 4 <1234>
