![]() | Home > Maintenance & Mods (L322) > gearbox oil |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
If you have a 2007 petrol model with the Jaguar engine then your transmission is the 6-speed unit (ZF 6HP26) which requires ZF Lifeguard Fluid 6.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Thanks Phil. That's what I thought. Was amazed (but then not that amazed) that the dealer here is out of tune with RR. They are absolutely useless normally...and yes mine is the Jag engine |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Look at the Ravenol website. I believe they actually make the oil for ZF. Half the price from them. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
They do indeed do a gearbox specific 6hp fluid which is designed for use in the ZF gearboxes. Whether they make it for ZF I’m not sure, however ZF is a automotive engineering company not a lubricant manufacturer.... so someone makes it for them.
I just put 2 and 2 together. German gearbox + German oil manufacturer.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Advance factors sold one which i think was meyle 6 for the six speed box or something like that which I belive someone used maybe Mikey, for servicing them and was supposed to be the same and about £10 a litre but i cant see it on their site any more. Cant seem to find the post about it though! Current 2007 TDV8 Vogue Buckingham Blue |
It does say it has the LR part specification. There is nothing that can't be fixed with a hammer😜😜
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Is Ravenol ATF 8 HP fluid the same, therefore, as ZF's Lifeguard 8 for the 8 speed ZF box?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3854 ![]() ![]() ![]() |
From their website.
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Have a look at the offering from Smith & Allen:
Wow that stuff from Smith & Allen is cheap. M1375.4 is the spec number to go by..
I agree Grofus - ZF do not actually manufacture oil and their gearboxes seem to be fitted to other manufacturers cars who all seem to have their own "special" fluid.
Well yes, but does "it's suitable" mean "it'll do, sort of" or does it mean "it's exactly the same stuff just with our own label on it since we actually supply ZF"? I suspect the latter, since (as pointed out) ZF isn't an oil manufacturer, but some confirmation would be good. I guess I should ask them! |
Thanks guys, just been looking at this offer here with Ravenol
