![]() | Home > Technical (L322) > 3.6 tdv8 injector blowing |
| Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55
This is quite common on smaller PSA engines like the 1.6 hdi and once the carbon has built up the injectors can be extremely stubborn to get out, LR recommend replacing the injector seals with a kit that includes the copper washer and the metal holding down clamp and but they charge the earth for each kit and by the time you buy 8 you will be crying so most people just replace the copper washer purchased from eBay or diesel specialists although maybe it’s possible that someone has tried to reuse the washers in the past and this is what’s caused your issue,
As Sharpy rightfully said, a dear old game so be sure your barking up the right tree first sir... |
| All times are GMT |
