![]() | Home > In Car Electronics (L322) > Automatic headlight delay |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Interesting as I had the similar issue but never relied on the automatic position. I now tend to use them as & when. I believe the sensor is on the top of the windscreen & I have known issues on other vehicles where they don't work correctly.
Update:- Thought that I would try the Auto route today & see what happens.
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 ![]() ![]() ![]() |
Worth baring in mind, they seem to know when the light from behind is brighter than the light in front (thanks to the sensors in the windscreen, and the ones in the rear view mirror that trigger the Electro-chromic dimming), and will come on to help make you more visible on the road during those "low sun" times. |
TimperleyRR Member Since: 13 Aug 2016 Location: Manchester Posts: 50 ![]() ![]() ![]() |
Thank you for the replies.
Definitely sounds like a sensor issue, especially as you are experiencing wiper issues aswell. Try covering the sensor when the lights are on auto during daylight & see how long it takes for them to illuminate.
Thanks Highroller
So here is an interesting one. Cover the sensors during daylight and it takes about a minute for the headlights to come on, but uncover them and they go off immediately. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16380 ![]() ![]() ![]() |
The lights & wipers work from the same sensor (above the rear view mirror)
