![]() | Home > Technical (L322) > Sending my L322 to sleep with me in it. Is it possible? |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 ![]() ![]() ![]() |
Is it possible to up an L322 (2005my) into sleep mode while sitting in it?
Thanks. I tried latching the drivers door yesterday, and I have tried both single press locking and double press, but so far I can't get the thing to go to sleep and still allow access to the fuses. Maybe I just need to leave it longer, but it goes off quite quickly when locked up normally. It even goes to sleep if I leave it unlocked with the doors closed, which I didn't think would happen. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
I would imagine that if you press the lock button on the centre dash, then it wont enable the ultrasonics inside. ( cause it knows you were inside when you locked it by pressing the button )
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Pressing the lock button once to lock and arm it and then press it again within 10 seconds to disable the interior protection. This is what I used to do when I left my cocker spaniel in it and if one of them doesn’t set it off then nothing will.
Aaron HSE Member Since: 06 Feb 2018 Location: Sussex Posts: 4 ![]() ![]() |
I have managed this.
good for you and top marks for actually coming back and posting your solution |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Well done and good result but have to say when I saw the title thought you were preparing a will and putting your burial requirements - glad you are sorted ![]() ![]() |
