![]() | Home > Technical (L322) > DPF ADVICE PLEASE... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
just run as you do now....if and when the yellow dpf warning comes up then run it at 50mph for about 10-20 minutes to clear it..
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
I got the yellow warning last October. Once the engine was warm, I used a little more right foot for acceleration while keeping it in lower gears |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
I too do lots of short runs. Stan's advice worked for me. Just let the engine get up to temperature then go for your 50mph+ drive. Holding the car in lower gears to get the revs up - as some people advised me - doesn't need to be done. What do I put here then? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1525 ![]() ![]() |
tI found in my freelander than ragging the nuts off the engine to clear the DPF was a waste of time. As mentioned above, driving normally between 50 and 70-mph seemed to be far more effective at clearing it.
GavinBell Member Since: 10 Sep 2017 Location: Phnom Penh Posts: 88 ![]() ![]() ![]() |
The dreaded warning came on for the first time in my ownership.....
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
Is DPF regeneration silent ? |
if it does make a sound you wouldnt hear it over the engine/road noise.... ... - .- -.
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
Thank you for the replies, very helpful |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 ![]() ![]() ![]() |
I didn't think the TDV8 3.6 had a DPF, I thought it was only introduced in the 4.4? |
it was optional,
