|  | Home > Technical (L322) > FF TDV8 2012 HEATER PROBLEMS |
| Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55      |
 Hi, i am hoping that someone can throw some light on my heater problems, if my heater on the drivers side is on full temp then it works fine blowing out hot air but as soon as i turn the temp down a fraction the heater blows cold air, passenger side works all ok its just the drivers side, so its either burning hot or freezing cold, can anyone help please, thanks | ||
|  10th Jan 2018 7:23am |
| Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55      | please help, someone must know something FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 | ||
|  11th Jan 2018 4:37pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | i'm guessing the blend motor maybe....something isnt regulating the hot and cold air.... ... - .- -.
|  11th Jan 2018 4:44pm |
| Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55      | Cheers Stan for your reply, is there a way of testing the blend motor or should i just look at replacing it FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 | ||
|  11th Jan 2018 4:47pm |
| abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93    | Did you resolve this issue?
|  10th Dec 2019 6:45am |
| Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55      | Hi, still unresolved, have had many people look at it over the last 12 months but all suggesting different things, so i am still looking for a definitive answer FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 | ||
|  10th Dec 2019 7:26am |
| Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55      | Hi, did it blow hot when turned to full heat? FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 | ||
|  10th Dec 2019 9:39am |
| umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433      | Yes very hot then cold no fine tuning. 2010 3.6tdv8 180k km.
|  10th Dec 2019 11:40am |
| Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55      | Hi, thanks, that seems like a low cost option to take so will order a new one and give it a go, was it easy to replace? thanks again FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 | ||
|  10th Dec 2019 11:43am |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | +1 for the resistor fix.
|  10th Dec 2019 12:18pm |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839      | Sadly, RR ownership and definitive answers to problems are unlikely bed mates.   | ||
|  10th Dec 2019 2:23pm |
| abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93    | Mine is definitely warmer on passenger side and pretty cold on the drivers side so I expect its the valve thingy under the bonnet someone pointed me at.
|  10th Dec 2019 8:17pm |
| Whyohwhy? Member Since: 13 Nov 2020 Location: Coventry Posts: 2      |
 Hi Guy's and Gal's, newbie here, but I guess I'll be a regular!
|  13th Nov 2020 4:38pm |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1432      | Heater problems on 322s are often solved by replacing the final stage resistor and lubricating the flap mechanism that directs where the air goes, that cured the two I had.
|  14th Nov 2020 9:10pm |
| Posting Rules
