![]() | Home > Technical (L322) > INACCURATE FUEL GUAGE READING - LR SENDER WIRING MOD? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35769 ![]() ![]() |
the trip computer also takes into account of the previous average mpg, ie, if you have only been doing town driving with low mpg it will take that into its calculations...if all at 50mph with better mpg ,it then takes that into account.. ... - .- -.
jz Member Since: 31 Mar 2016 Location: London Posts: 55 ![]() ![]() |
Thanks and yes understand it's dynamic. Why I'm asking, with now mod allegedly now done the car now shows ~305 full range mileage reading when full to the brim prior to the work being done it was ~338, so to get worse makes no sense to me.
bump
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Can't scroll through the trip computer display options and get the present MPG? that way you could work out what it should be on a full tank ie. MPG x 23 = range!! Yesterday I couldn't spell Engineer... Today I are one!
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
I think tank range on the dash is just a guess. You're better to test its accuracy for 3 tanks. Just reset your trip each time you fill. Try to fill to brim and fill up as empty as you dare. I just filled my 4,4 diesel with estimated 12 miles to empty and it took 90 litres. And what is empty anyway? 10litres remaining? 5? 0?
JZ probably the best explanation it that the reading before the fix was inaccurate therefore giving you optimistic range estimates.
![]() There is another thing to bare in mind... the garage might have done a reset... and you haven't driven it over 30 (being optimistic as you say you live in London, some parts you're luck to get over 3 mph!!), if you have never reset the the computer then it will be taking all the historic readings as well, and it might have spent years cruising on motorways.. which would give it a high reading on the average MPG and directly effect the fuel range. ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
