![]() | Home > Technical (L322) > Lost cons to mid can |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Morning all my l322 has lost coms was displaying lost sync with mid can
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
It sounds like a power issue to me. Check your battery voltage. Do you get dashboard lights on. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Right update battery with booster pack on showing 15v and 12.5 with ignition on Iid tool connecting but still saying no connection to Mid Can . It will read faults but when I clear them it says update failed. Tried CCF restore went through the whole cycle and said update failed - anyone with any idea on how to restore comms to mid can |
Might be be worth an over night charge. 12.5 v is ok but not great. What is Mid Can? I'm guessing Canbus but it is a guess. Suggest an email fired off to Gap. Glad progress is being made. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Right problem solved had a landrover electrician come over identified a broken wire behind fuse box on passenger side replaced and all back to normal |
