![]() | Home > Technical (L322) > Who can you recommend to supply an Air Spring for my L322? |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Ask Dan - duckworthparts on this forum - for a price.
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
2nd that |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7979 ![]() ![]() ![]() |
You don’t need a new compressor mate....fix it yourself - it’s only the filter on the air outlet blocked....
Sukh Member Since: 24 Mar 2014 Location: Berkshire Posts: 2 ![]() ![]() ![]() |
Thank You for recommending Dan, will contact him ASAP!
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi,mjdronfield
I understand you can soak it in Petrol to maybe clean it, but I decided to drill a small hole. I still can’t hear it so no downside but won’t block again.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
We had a similar problem at work with a 14" valve actuator that was really slow to respond. The Inst Tech showed me a sintered filter that he suspected was blocked. A replacement was going to take ages to appear (good old SAP) so I told him to drill it. He was gob smacked when it worked! Previous cars:
