![]() | Home > Technical (L322) > Battery totally dead and key won’t turn and won’t charge |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
Went out yesterday as the alarm started going off only to find it totally flat. Last time I drove it was Saturday. I unlocked the door with the key and tried it in the ignition and it wouldn’t turn, I’m guessing this is because the battery is flat? Also I’ve had a new battery in the last two months as my last one went flat and it all pointed to a faulty battery. I’ve tried putting it on my ctec mx5.0 charger and it kept on giving me a green flashing light, eventually it started to charge but I’ve gone out this morning and it’s flashing red now. Surely I can’t have another dodgy battery, both Varta battery’s. Also is it possible my charger is faulty also or is it because the battery is so flat that it won’t charge?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8091 ![]() ![]() ![]() |
Sounds like a knackered alternator to me.......
I had the RAC out last time it went flat end of October and everything checked out except for the battery. I suspect I have a drain |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Can you turn on your headlights on main beam? |
I couldn’t do anything, I had no power at all. My mate popped round and we jumped it, took it round the block and it restarted and now I have another charger on it overnight. 2004 RR 4.4 V8 Autobiography |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I think you need to check for a parasite |
You will need to explain what it is exactly I’m looking for. 2004 RR 4.4 V8 Autobiography |
If your battery charged by a short drive i would guess your alternator is ok but use a voltmeter and look for around 14.2 + volts across the battery at idle.
Ok thanks for the explanation, looks like I will need to get the multimeter out at some point. I’ve got one of those solar chargers and I’ve ordered a new ctec mxs5.0 with the extension so may just leave that plugged in for now. 2004 RR 4.4 V8 Autobiography |
