Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 4 of 27 <123 45 ... 252627>
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Censored !
Thought as much, was just interested to tear it apart 😁
Post #464301 12th Jan 2018 6:11pm
Zeppfish
If memory serves, there were 4 wires coming out of it, and I think that 2 were green, and 2 were yellow!!!! not much help. I am not even sure If I kept it! Ill have a rummage around the work shop and If I find It ill put a picture up 2006 RR sport HSE
Swapped for 2012 4.4td v8 Westminster Santori black with Ivory leather
BEEN SMILING EVER SINCE
Post #464305 12th Jan 2018 6:54pm
millerj90
That is absolutely correct, and from what I can see the go directly into the plates. As soon as my replacement arrives, I’m going to break it open. 😁
Post #464311 12th Jan 2018 7:53pm
Fatfred
in regard to the heated/cooled seat control module, i see lots that look identical but have different part numbers, mine is
AW93-14B663-AD
Have seen others available with part numbers
HLV500060, HLV500070, HLV500080
AW93-14B663-AC
can anyone tell me if these are all the same part and are interchangeable, thanks FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #464322 12th Jan 2018 8:47pm
Zeppfish
Millerj90i was hoping to hot wire mine into working with an external thermistor, and use the whole assembly to heat the air in my biltong drying box! But I was a little over enthusiastic with the tear down Whistle 2006 RR sport HSE
Post #464365 13th Jan 2018 6:04am
millerj90
Zeppfish - great idea, good biltong is hard to get around here!
Post #464380 13th Jan 2018 10:50am
supershuttle
This got me to thinking - again dangerous - a thermistor is just a heat sensitive resistor so if the value of the resistance was known for a given heat the thermistor could simply be replaced with a resistor in line for a fixed heat setting. Geoff
Post #464430 13th Jan 2018 5:29pm
Zeppfish
Geoff
That would work in theory, but it won’t take into account the other variables! Ie size of the arse on the seat and the effect of the air flow around or even from it lol Rolling with laughter Rolling with laughter 2006 RR sport HSE
Post #464436 13th Jan 2018 6:06pm
supershuttle
I think its time I got my order in, if only to stop comments regarding my more than ample arse that needs warming up on a regular basis Whistle Geoff
Post #464453 13th Jan 2018 8:42pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Has anyone tried swapping the peltior unit from the squab into the seat back to see if it resolves the non heating problem without spending £260 on a new back module (heater and fan unit )?.
Post #464677 15th Jan 2018 6:03pm
Zeppfish
Unfortunately the pettier cell in the back has the thermistors in, and the squab has none as the back unit controls the pair! 2006 RR sport HSE
Post #464679 15th Jan 2018 6:12pm
matthews
Are you sure as looking at my underseat one it has the same 4 wires (2 green , 1 blue and 1 yellow) going into it as the one in the seat back ? Surely as it's a separate unit it will need the same type of temp control to stop any overheating .
Post #464682 15th Jan 2018 6:17pm
Zeppfish
I was only going from memory as mine happened early last year!
I would imagine all the peltier cells are made the same so as to save production costs????? In witch case it could be worth a try swapping them over to see if that does the trick? Might be the cheaper option we are all looking for.
I distinctly remember reading somewhere that the seat back unit controlled the heat output as it was always on when the heated seats were on, so therefore was the master! Where as the squab unit can be user selected on or off, so would only mirror what the seat back unit was doing.
I might be wrong though!!! I'll have a rummage around to see where i read that info! 2006 RR sport HSE
Post #464983 18th Jan 2018 10:39am
supershuttle
Has anyone done this yet, did it work? Geoff
Post #465422 21st Jan 2018 6:23pm
millerj90
Not yet. Weather has not been conducive to ripping the seat out. But it does make a whole lot of sense
Post #465426 21st Jan 2018 6:57pm
