Home > Maintenance & Mods (L322) > ECU upgrades , IID tool
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hey
I identified that my transmission and transfer case ECU had SW upgrades available, so I ordered these from GAP
As the transmission needs an adaptation reset , I assume that , as I also plan to change the sump and flush the oil , the order of events should be
1 service transmission
2 clear adaptations
3 reflash latest SW
Do we agree or should I clear adaptations and flash prior to the service ?
Also, I see other ECUs with available upgrades - is it worth purchasing the latest upgrades for TV , instrument pack , audio etc
What are the benefits offered by the latest SW ?
Was also surprised at a £25 per ECU admin fee for the upgrades , would have expected the latest SW versions to have been applied as part of the dealer service - my new to me 4.2 Fatty was main dealer serviced up to a couple of years ago , prior to services by a local garage .
Is it possible that upgrades have been released in the last couple of years ?
Thanks for any insight P525
4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #464314 12th Jan 2018 8:08pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
More likely the dealer won't do updates unless you ask them to fix a problem with something linked to one of the ecus.
Post #464337 12th Jan 2018 10:04pm
m@ttsFF
Thanks , I guess that could be just it .
I haven’t really taken much notice of the SW updates to my cars for a while , but the bikes always get any available SW updates applied as a matter of course when in for service P525
Post #464527 14th Jan 2018 3:13pm
m@ttsFF
So this week I changed the transmission oil and filter and then drained and refilled 3 more times ,
All straight forward and simple to do - looked like the sump had been changed previously but the fluid was still very dirty .
Clean as new oil after changing /draining 16l
No faults really with the transmission.. other then a bit of a clunk dropping back from second into first and hanging on to gears longer than I’d like , kicking down quickly when not really required (I put this down to maybe the car had been used for towing before I got it)
After the oil change everything felt smoother , but as I’d ordered the ECU upgrades today I proceeded with the flashing
Step1 -Menu->Service Test->Transmission->Clear Adaption
Step2 -Menu->ECU Flash--Transmission
Step3 -Menu--ECU Flash--Transfer Case
Step4 -Menu--Calibration--Transfer Case, proceed with both items
Well , I’m delighted with the results . Changes up and down are silky smooth (much like the 8spd in my 2016 5 series) and changes up to 6th much earlier than it did before the clear / reflash P525
Post #474344 30th Mar 2018 12:22pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
Do you have the version(s) you flashed from and to for interest?
Post #474375 30th Mar 2018 6:14pm
m@ttsFF
This is the IID tool generated report before upgrade - I’ll need to re-run now they’re upgraded I guess
Transfer box is the first one
 P525
Post #474380 30th Mar 2018 6:45pm
m@ttsFF
Latest versions
 P525
Post #474410 31st Mar 2018 12:01pm
unsolicited
Thanks for that. Must scan mine & see how far behind it is!
Post #474513 1st Apr 2018 7:48pm
