Home > My Range Rover > range rover with problems |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Use this to find febi parts.
11th Jan 2018 9:04am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
Britpart
11th Jan 2018 4:34pm |
Yours is the 4.4 V8 2002 - 2005 (maybe sneaking into 2006) which is the M62TUB44 BMW engine, the other 4.4 engine started 2005 ish but really 2006 - 2009 and is the Jaguar engine https://en.wikipedia.org/wiki/Jaguar_AJ-V8_engine#Land_Rover_4.4
11th Jan 2018 9:40pm |
thanks for that info holidaychicken, i thought it funny, that motor running to 2010
12th Jan 2018 12:31am |
nice one mate, i just checked and triple checked everything and really took my time, have a watch of that series of videos over a few times, it really helped me and it did that before i even started
12th Jan 2018 12:45am |
i have been trying to down load this, can it be down loaded
13th Jan 2018 7:52am |
your link doesn't work, if it is the instructions you are trying to to download then go to the link below and then download the pdf from there. On my screen where the pdf shows there is a down arrow at the top right corner of the screen to download.
13th Jan 2018 5:43pm |
Thanks again, have managed to down load that link.
14th Jan 2018 2:39am |
Thats ok you don't need that thing, it's part of the crankcase ventilation i believe but yours is at the back of the engine in a marginally easier place to access.
14th Jan 2018 10:12am |
Just to update my own ramblings regarding the sealant, i contacted Loctite / henkel who replied very promptly and with lots of good information but in summary, 598 is a very old product, 5980 is a newer version and something to do with labelling but the 5900 is recommended with the 5910 being a slightly lower viscosity version with a slightly longer curing time which is what i will be going with when i pull mine apart again in a few weeks time. |
15th Jan 2018 8:24pm |
Haven’t worked on my RR for a while, the tail end of a cyclone came through so I had to cover everything up and I have been busy doing other things
3rd Feb 2018 2:01pm |
While it was raining, I made some chairs to hold the cam locks down, only fitted one at this stage but they seem to work quite well RR 2005 4.4 petrol
3rd Feb 2018 2:04pm |
i hope some one dosnt tell me its a right hand thread RR 2005 4.4 petrol
3rd Feb 2018 2:09pm |
They are left handed, i would imagine somebody has had a problem with them coming loose, which i have heard of or they were just being over careful and they have used loctite on the threads. i think it is when cheap torx bits have been used that twist rather than tighten the bolts
3rd Feb 2018 4:29pm |
