Home > Technical (L322) > Glove box fuse access
Roadking
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Started fitting a dash cam today and got stuck at the point where I was looking to access the fuse box in the passenger glove box. The handbook and videos I've seen show the right hand stay being unclipped (which I have done) and no mention of the left hand stay. In any event, I can't see how that would unclip.
How hard do you have to push to lower the lid when the right hand stay is disconnected? I don't want to break it!
Any help or advice would be appreciated.
Mike
Post #464420 13th Jan 2018 4:30pm
GGDR
Mike do you mean the panel directly covering the fuse board? I'm not sure about any 'stays' there are two clips top left and top right as I remember. Pretty stiff too. Gently prise the clips down then pull the cover towards you.
You might find it easier for access to remove the whole lower glovebox if you're running wires. Quite a few screws but much easier access.
Greg Cheers, Greg
Post #464423 13th Jan 2018 4:51pm
Roadking
Greg,
Thanks for that. The fuse box lid looks simple enough once the lower glove box is dropped into its "service" position. The trouble I'm having is getting it dropped to that position so the back of the glove box is obstructing the fuse box.
I hear what you're saying re removal, but I'd also like to resolve how I could check a fuse by the side of the road. The handbook shows full access to the fuses by unclipping the right hand stay.
Mike
Post #464432 13th Jan 2018 5:35pm
Roadking
Got it!
Handbook is handed for a LHD car I think. Stay unclips left, not right as per page 235 of handbook. Once you sort that out, its easy, even by the side of the road. Photos attached for the record.
Top photo shows access with lid in service position.
Next shows what I thought was another stay, but looks like the hinge mechanism.
Final shows stay and hole it lives in. The foam gave it away regarding direction of travel.
All in all, I would have been better not bothering with the handbook!
Pictures rotated when uploaded so top as viewed in post is towards the centre of the car.
Mike
Post #464437 13th Jan 2018 6:10pm
GGDR
Ok so it's the glovebox you want to drop. The stay has a barbed end so open it as normal and it hangs on the 'stays'. Then pull the top end of the stay towards the opening of the box. I think that's right for both. Only proviso to this is that I'm saying this from memory. I can check mine in an hour or so. Cheers, Greg
Post #464438 13th Jan 2018 6:12pm
Roadking
Thanks for that. I got it when I went out to take photos.
Post #464440 13th Jan 2018 6:35pm
I didn't know you could do that. Does it apply to all models/years ? .
Post #464443 13th Jan 2018 7:31pm
Roadking
Not sure. Do they all have a lower glove box?
Post #464450 13th Jan 2018 8:25pm
