![]() | Home > Maintenance & Mods (L322) > Brake pad recommendations |
Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212 ![]() ![]() |
Brembo, mintex or factory
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35681 ![]() ![]() |
always go OE...some have had good results with other makes but generally OE is best.. ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8006 ![]() ![]() ![]() |
I've always found the factory OE the best - others are either noisy or excessively dusty
Ok thanks for the advice, obviously at some point 09/10 they started putting brembo calipers pads and discs on at the factory, do you think it could be wise to try that or stick with OE? 2018 Suzuki Jimny 2003 written off
There may well be better pads out there, I just haven't come across them - thought others may have. I haven't done an exhaustive test, with all calliper/disc combinations, but over the years I've tried 3 or 4 different ones and swapped again under 5000 miles later.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
In 100K km that i did in my car in 2.5 years I went through LR pads, EBC discs and Yellow pads, and now i have masined original brembo discs and JURID pads in front. EBC I changed after cc 2000 km, disks where warping under hard braking and pads were noisy coming to a stop. JURID are as good as LR in stopping power and they are quiet, and they are available locally.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
ebd redstuff are great no dust and ceramic pads so no metal particles and the stopping and using distances are superb youd never go back oem |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Unnecessary quote removed
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I have Brembo pads on the front and my alloy rims are black, have to clean the wheels every few days so not happy. I have Delphi pads on the rear and my rear wheels are clean. |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Always remembering that it is the front brakes that do most of the work - so cleanliness of the rears may not be a fair comparison. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1817 ![]() ![]() |
OE o r uprated |
