![]() | Home > Technical (L322) > Water / Condensation in Front Headlamp |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125 ![]() ![]() ![]() |
It's relatively easy to remove the headlamp - take the front grill off (3 screws) and then undo the 3 screws that hold the lamp in place. Lift out and disconnect the plugs remove the caps on the back of the unit where you access the sidelight bulbs and drain the water out from there. The headlight should be sealed but if you've got a cap missing that would be your possible way in for the water. |
Lamp covers number 10 in diagram - open and drain.
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 834 ![]() ![]() ![]() |
Now you've given me such a detailed solution, I've got to have a go haven't I....... Thank you for taking the time out to send me this NobbyC, it's very much appreciated.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Does it clear when the lights have been running for a while? Alex
Hi Alex
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766 ![]() ![]() ![]() |
So remove as above and use a hair dryer to dry it out, then leave it overnight at room temperature!
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
I had an old headlamp (2003 model) which had a broken bracket so needed a new unit. There are a number of metal clips which hold the headlamp glass onto the casing, if you are very careful you can prise these clips off and remove the glass from the unit itself. If you can do this it may be worth running a bit of clear silicon sealant around the glass when refitting it. |
Cheers guys, will investigate this weekend |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 407 ![]() ![]() |
I'd be doing this. Easy even for an amateur bloke. A dealer will just tell you that you need a new headlight. Those blokes are fitters not mechanics. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1991 Mercedes 420 SEL |
I know what you mean about them being fitters...... That's my fear, they're all sharks, they'll just do what's easier and more profitable for them.
