| I have a 2007 L322 Vogue, 3.6 TDV8 . about a month ago I had a problem where the RR wouldn't start, No dash lights like Battery etc. when I turned the Key, I did however get the dash screen , Windows, Radio etc. to turn on and I could move the Selector to any position. but the RR would not start. So I got on to the Dealer that I bought it from and he said it was possibly the Battery, I checked the symptoms on the Internet and yes it was 1 of the possibilities, so off I went and bought a battery, put it in and No Difference.... Still wouldn't start. Then I got a Specialist Auto Electrician, he spent 2 days , stripped out and traced all the Wiring , checked for broken or damaged cables, Nothing found other than some type of moisture on a plug under the Handbrake switch. In the process of re assembling the interior the dash lights came back on and the RR started.
That's not the end of this one just yet.... It worked with the problem showing its head only intermittently up to today when the RR has refused to start again with the same fault, no Dash lights when you turn on the Ign with the Key , engine will not turn over , but all the other electrics in the RR work as they should except that the Electric Handbrake will not engage.
 At this point I am lost , Has anyone else had this problem and more importantly have they resolved it . Any help would be greatly appreciated........ Thanks in advance.
