![]() | Home > Technical (L322) > Part Numbers Request Please |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2732 ![]() ![]() |
According to 2012 Microcat for 2002 ZF 5-speed for M62 B44 4.4 Petrol V8
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Find part numbers here as you will need o rings from memory and I changed my thermostat and holder and banjo bolts when we rebuilt my transmission so everything was new.
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 930 ![]() ![]() ![]() |
Thank you |
Will I need to replace ATF fluid? And do I need more than 1 O ring? Cheers |
I can't remember exactly but if you follow the procedure through in Rave, - download from the wiki it will tell you what to remove / replace . http://www.fullfatrr.com/wiki/Main_Page
