![]() | Home > Technical (L322) > [solved] Where should this connect to? |
Tooltime79 Member Since: 03 Jun 2015 Location: York, North Yorkshire Posts: 27 ![]() ![]() ![]() |
I was just checking over the car this afternoon and noticed a small pipe was dangling under the air box. Looks like a vacuum pipe but I can’t work out where it should connect to. Anyone got any ideas? Circled red in the photo.
Thanks Mike - I did have a look last night in the WM but couldn’t obviously see it identified (probably because I don’t know what it actually is for!)....will have another more careful look though.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
Check out this link.
HI Mike,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
might be worth finding a similar FF and comparing the engine layout Tim.. ... - .- -.
I think you might be right Stan. Doesn't seem to be bringing up any fault codes or impacting on performance so can't be that important! |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Maybe rename your post need help from 3.6 owners, they are a lovely , helpful bunch ( i used to be one ) 2015 4.4 AB
Stevie_b Member Since: 22 Jul 2016 Location: East Kilbride Posts: 11 ![]() ![]() ![]() |
Hi, I'm sure it connects to a pipe on the air box |
Stevie - thank you! You are spot on...I have now found it in the workshop manual, something to do with a port deactivation pipe. The reason it isn’t connected is that the plastic bit it is meant to connect to on the air box seems to have snapped off which is why I couldn’t see it before. Now just need to find a way to reconnect it!
No bother, good luck in the repair.
