Home > Technical (L322) > Is there a 4.4 tdv8 check list ?
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hi all,
I have searched and read loads of posts on here, but i can't find a buyers guide / check list for the later cars.
If there is one i apologise, please point me at it Wink
I am off to view and hopefully buy an autobiography black later in the week.
The car looks immaculate in the pictures., and everything electric works, which I will obviously check.
Are there any things I should be checking for with the engine, running gear, or body work ?
I see there can be a rear engine o ring leak, though doesn't look like I can easily check that.
I also noted the potential rust issues around rear arches, so will check those.
Finally, if anyone has a pdf of the sales brochure / price for the black edition I would love a copy.
I have a 2010 brochure but it doesn't cover the 4.4tdv8 or black edition.
Cheers,
John.
Quite excited at soon to be owning a rangey again Cool
Post #464818 16th Jan 2018 9:33pm
Stuart-
I've just bought an Autobiography Black and I'd also like to see the spec and the new price lists if anyone has that.
Sorry I can't be much more help to you, John. I've had enough cars I just did it by feel and common sense. And with one of these as with any Rangey, expect a big bill in the first few weeks of ownership. Something that *never* goes wrong on any car wont work on it. However much you read, you'll miss it. Big Cry 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
2006 Bentley Flying Spur in silver
Post #464827 16th Jan 2018 10:19pm
John w
Thanks Stuart.
I've had a bunch of cars too but it's always handy to have an idea of what to check Wink
I hope I don't get a big bill in the first few weeks. Well, not unless it's by choice Very Happy
Does your car have full postcode search or only 1st 4 characters ?
If it's only 1st 4 I hope it can be upgraded (no doubt the first big bill Laughing Laughing Laughing )
Post #464832 16th Jan 2018 10:47pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Baltic Blue is your man to ask!
http://www.fullfatrr.com/forum/topic44115.html?highlight=4+4+tdv8
Post #464833 16th Jan 2018 11:06pm
John w
Thanks for that, just what I was after Thumbs Up
Not quite sure how I missed that thread Rolling Eyes Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #464839 16th Jan 2018 11:27pm
Stuart-
John w wrote:
Thanks Stuart.
Mine has full postcode input. 2017 4.4 SDV8 Autobiography in black
Post #464880 17th Jan 2018 12:45pm
Baltic Blue
John w,
Make sure you get the engine revs up to 2,500+rpm.
Lookout for clouds of exhaust smoke.
Excessive smoke suggests it needs the Turbo drain mod. (Approx £1k ) at a good independent.
If it trips into restricted performance start asking questions.
Post #464881 17th Jan 2018 1:11pm
..also a John, the sat nav should have the latest maps available which are 2014.. you won't get get anything newer than that unfortunetly... ... - .- -.
Post #464883 17th Jan 2018 1:49pm
John w
Thanks Mike, will do.
I found your thread about this http://www.fullfatrr.com/forum/topic40047.html
Is the turbo drain mod a diy job ?
I am mechanically competent, so if a mechanic can do it, so can I given the right tools Wink
I see you said you had a paper copy of the bulletin. Is there a pdf version about yet ?
I have asked the seller if it has been done but I suspect it hasn't or think he would have mentioned it.
It had an mot this week, would that pick it up if here was an issue ?
I assume a Dec 10 regd car is too old for LR warranty now ?
Not that I usually bother, but worth knowing Very Happy Too many toys, not enough time
Post #464887 17th Jan 2018 2:28pm
John w
Thanks Stan. If it doesn't have latest is this a main dale only update or just a new DVD ?
What sort of cost is it ? Too many toys, not enough time
Post #464892 17th Jan 2018 2:33pm
Baltic Blue
John w,
Turbo drain mod is in the Wiki under engine section.
It involves removing the front subframe and some very precision drilling.
Not a job for the faint hearted 😂😂.
PS,
Some owners don’t think it is worth doing because they just keep it in check by regularly getting the revs up and thus burning off the oil buildup.
Post #464895 17th Jan 2018 2:37pm
main dealer for the sat nav update to 2014, cost around £165...
it might be worth investing in a secondary nav unit
i have a cheap chinese jobby that runs igo primo with the latest 2017 mapping ,cost around £25 .. ... - .- -.
Post #464897 17th Jan 2018 2:45pm
John w
Just read the service bulletin Shocked
Erm, I might give that a miss Laughing
I've done some big jobs in the past including dropping and replacing the turbos on my 997 turbo, but drilling holes in blocks is a whole different story Whistle Too many toys, not enough time
Post #464902 17th Jan 2018 4:03pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
"PS,
Some owners don’t think it is worth doing because they just keep it in check by regularly getting the revs up and thus burning off the oil buildup."
- everyone thinks you've blown the engine and smirks at you. If I were buying a 4.4 again if it did not have the mod then I could simply walk away (or get 1500 off the price)
John - send me an email via PM and I'll send you a 2011 price list (not including the black but does inc the 4.4) 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #464910 17th Jan 2018 5:17pm
Baltic Blue
Adrian,
Mine got a bit embarrassing.
I don’t tend to get the revs up very often, but when I did, usually trying to overtake a line of slow moving lorries, I would always leave them in a fog, and be checking around for Police cars.
I argued with JLR until they. agreed to do the work.
Post #464923 17th Jan 2018 6:27pm
