Home > Maintenance & Mods (L322) > Windscreen replacd today - possible problem.
Andy
Autoglass came out to fit my new screen today. Took longer than anticipated as the scuttle plate had previously been bonded onto the original windscreen and they had to cheesewire it off. Not sure if it was done at the factory or not. The scuttle plate now has to be replaced thanks to whoever bonded it on.
Anyway- new screen looks great but I’ve noticed I can get my fingers up over the roof lining now where it meets the screen. I never tried to do this before so I don’t know if it’s always been like this but nothing seems to be holding the roof lining in place.
Can someone check theirs to see if they can do the same?
TIA
Post #464913 17th Jan 2018 6:57pm
there is a gap, i hide my dashcam cable up there but you'd have to pull it down a tad to get fingers up there... ... - .- -.
Post #464917 17th Jan 2018 7:14pm
Andy
I can grab the rooflining with the tips of my fingers and pull it down. Nothing seems to be holding it in place. Seems like it needs press clips or something
Post #464918 17th Jan 2018 7:17pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Andy
That’s sounds normal. As Stans says, it’s designed to hide dash cam cables. Laughing
John
Post #464920 17th Jan 2018 7:19pm
Andy
Funny you should say that- When I looked at it with the screen out, I was tempted to shove my dashcam cable inside the void between the lining and the shell before the screen went back in.
Post #464922 17th Jan 2018 7:25pm
Andy
So- anyone else have the same issue?
Post #465011 18th Jan 2018 3:32pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
The piece of plastic below the screen is indeed sealed into position - the fitters didn't re-seal it when I had my screen replaced a couple of years back, and it vibrated something awful!! Got them back out and they glued it down properly - no problems since. Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #465014 18th Jan 2018 3:56pm
Fatfred
hi, did anyone have any problems with the rain sensor not working after a screen change, i had mine done in the summer last year and after the rain sensor is not working, any suggestions would be grateful FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #465072 19th Jan 2018 8:37am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Did the fitters simply forget to reconnect the elec connector? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #465134 19th Jan 2018 4:38pm
The rain sensor and headlight sensor stopped working on mine when my windscreen was replaced a few years ago.
The fitters fitted a replacement and then a new sensor but still nothing.
The ONLY thing that cured it was an OE Pilkington windscreen. It's been documented on here any times. Si. <This is my name.
Post #465244 20th Jan 2018 4:22pm
