Home > Maintenance & Mods (L322) > L322 headlights upgrade 2006 to 2010 turn signal problems
defenderv8t
Greece 2006 Range Rover Vogue 4.2 SC V8 Barolo Black
Hi to everybody,
I swap my front and tail lights from the newer model 2010 - 2012,
The rear tail turn signals works perfect with the resistors.
The headlights turn signals with the resistors fit on them, when engine is not running works perfect, when engine starting only the front turn signals stop working.
I have put the resistors and the connectors for the front headlights from powerfull.
Can anybody help me..
Thanks in advance.
Post #465143 19th Jan 2018 5:55pm
Your LCM is fighting with your conversion...
The easiest & cheapest resolve for you is to run both front indicators through a relay each side powered by the usual fused battery connections and the trigger feed, use the side repeater feed... Thumbs Up
Post #465184 19th Jan 2018 10:56pm
defenderv8t
If i put in parallel with the front turn signal wires, 12v common bulb what you think will be the result?
Post #465205 20th Jan 2018 5:44am
