![]() | Home > Technical (L322) > Low Coolant Temperature |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Is it a td6? If so, as you say it's a very common problem and most likely the main thermostat will be the cause. |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Yes TD6, just trying to put off the inevitable really |
Yeh, I know what you mean. Mine wants doing as well as never goes past a quarter in the winter.
It does have an impact. All the symptoms you describe happened to mine and were rectified when I changed the EGR thermostat. It's also very easy to change the EGR thermostat compared to the main thermostat. But if you've blocked it..... |
So did this job at the weekend, replaced the thermostat. Thanks to Joe90 for his write up |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Fitted a new EGR stat to the TD6 I have been caring for as the temp really struggled to get past the 10 O clock position and there was a real improvement with the needle mainly sitting at 12 o clock and the mpg has improved dramatically.
If you've got IID it is interesting to monitor temps, with the new stat it is now consistently in the 80's once warmed up, interestingly thought it won't warm up at idle/town speeds, needs a couple of good runs to get the temp up.
I have a faultmate registered to it at the moment and before i fitted the EGR stat the temps were in the 50s and 60s as it was around freezing outside. i haven't checked it since i replaced the EGR stat but the needle gets up to the middle and stays there most of the time but as you say it is only when i move off it comes up to temperature, sitting at idle it doesn't get that hot.
