Home > Maintenance & Mods (L322) > steering column extending / retracting woes L322 2004
Glenn*
2004 Range Rover Vogue Td6 Giverny Green
Help needed!!
used FF this morning no issues, lunch time set up a new key [ in and out of ignition a few times]- no problem,went to started FF - flat battery, put on charge for 10 minutes thinking it may be enough to get started as I said no starting issues to date.
with key in the start position [still won't start as not enough charge] steering column started to extend and extend fully then started to make a whirring noise as it could extend no more , now charged and starting but can't adjust column in or out and when lever used to try and adjust still making a whirring noise with nothing happening, movement on up and down ok.
any ideas anybody.
Thanks in advance
Post #465421 21st Jan 2018 6:21pm
Dolphinboy
It’s all well documented on here. Do a search. Sounds like your nut has dropped off! Shocked
Post #465486 21st Jan 2018 11:08pm
Glenn*
just ordered new nut from Ulrich [Meerbush]
sound like the plastic nut as worn,hopefully this will do the trick
Post #465487 21st Jan 2018 11:17pm
Glenn*
update
Decided to tackle the steering column this morning, stripped casing away exposing the threaded bar and plastic nut.
The plastic nut I bought from Uli is not needed, the issue is the spindle from the motor to the threaded bar.
I had done some investigating on a replacement metal spindle, Uli gave me a company name of Brit-car that supplies a genuine Land Rover part- press metal spindle dimension - 175mm long and 15mm square, unfortunately this is no longer available or the correct size.
This is a fair chunk of metal and as the threaded bar is only 9.5mm , this is not going to work.
I removed threaded bar as if your going to replace plastic nut then pulled the press metal bar out, hoping i could take some dimensions, this was not possible as the pressed metal had snapped off at the threaded bar, when I pull the rest from the motor you could see the the strands of metal that had been pressed had unfurled .
The fix
you need - 4.7 mm dia bar [I used stainless] @ 110mm long, 15mm on each end needs to be squared off to 3.8mm to fit in each end of the In/out motor and the threaded bar.
replace the threaded bar and plastic nut grease up, put steering column shroud back, and turn key and bingo all back working 1.5 hrs later, well chuffed.
Any one needing a plastic nut, I have one , Uli discounted mine for club member @ £42, I'll do the same £35.
Hope this helps solve the In / out steering issues if it's not the Plastic nut.
Post #467316 4th Feb 2018 8:37pm
