![]() | Home > Technical (L322) > dealer clearing faults |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
my suspension seems higher since my FF came back from a service at the main dealers so if they clear any faults using their equipment, will my eas settings made by the iidtool be reset as well.. ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
Can’t you use your IID tool to check the settings ? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
They have probably had it lifted on a 2 post ramp with all 4 wheels dangling.
@alistair ,havnt had the chance to do that yet but will do...
i cant see why it would either as my other settings on the CCF are the same..
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
There's your problem then ...
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Have you lowered yours then Stan?
I replaced my 20" wheels with 22".
i lowered mine by 15mm Paul...this helps a bit in reduced roll in cornering as well .. ... - .- -.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Mine went in once for a service and some additional work and I was convinced it was slightly higher afterwards as well. Took it back and it was adjusted. In theory if they did a software update I could see it would put it back to standard, much the same as a software update wiping over a remap.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Careful how much you say to them Stan or they will bill you for suspension reset |
never thought of that Sandy |
Mine only went back as it had a list of mistakes they had made and had to rectify which I found out the day I was leaving for holiday.
OJ Member Since: 05 Jan 2018 Location: Scotland Posts: 26 ![]() ![]() ![]() |
May be the original settings have been overwritten, did you save a copy on your ID tool, its not something daft like the height selector switch been moved, |
