![]() | Home > Technical (L322) > Camera module related fault codes (2010 autobiography) |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2776
The surround camera module is underneath the front passenger seat. |
| John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447
Thanks Graeme that's just what I was after.
It will activate on specific canbus messages. |
Thanks.
The letter P after the fuse number indicates the Passenger compartment fuse panel. E=engine, R=rear.
OK, thanks.
Does it have surround cameras or only a rear camera? If only a rear camera then no surround camera module will be fitted.
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
Just a thought.......when the battery was replaced, did the owner perform the battery reset procedure (start engine, turn steering all the way left, hold for a couple seconds, then all the way right and hold for a couple seconds)?
Hi guys.
Just trying to eliminate the obvious first.
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
Stan has written how to disconnect/ reconnect battery, it is in the Wiki, may be worth a try. |
Thanks guys.
| All times are GMT |
