Home > Maintenance & Mods (L322) > Jacking Points with deployable steps
Danwilderspin
Hi All, I know both these points have been covered in great detail, but not in the wy I'm asking..
as I am halfway through fitting the steps and they are not powered yet haven't had the time to do the loom etc. I snapped a couple of the bolts so reluctant to remove them.
Anyway needed to get under the car last week to do the brakes - no bigger jacked under the suspension... however I think I have bent lower arm up front and as I would jack there I need to know what else is good for jacking up front if thats what I'm changing?
I also tried removing the 4 Allen bolts in the steps and tried pulling off but it wouldn't move am I doing something wrong?
Thanks
Dan Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #465684 23rd Jan 2018 12:26pm
for jacking from the front use this method,
when you have undone the 4 allen bolts, 'knock' the steps upwards and they will some off.. ... - .- -.
Post #465685 23rd Jan 2018 12:33pm
Danwilderspin
Great it goes up I was trying to pull out - jacking on the subframe to do the arms is probably better anyway I'm guessing? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #465686 23rd Jan 2018 12:35pm
Danwilderspin
just thinking as its up I cut lift it up Sad Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #465997 25th Jan 2018 4:20pm
