Home > Wheels & Tyres > A question about LR037742 L405 19" alloy wheels.
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
A friend is in the considering the practicalities of chopping his D4 in for a FFRR
He has a particular need for smaller wheels and deeper section tyres. He would like to know if the following wheels are likely to fit all L405's, especially SDV8 Vougue SE / SDV8 Autobiography, or whether there are any limitations on which models that they will fit.
LR037742 - RANGE ROVER L405 AND SPORT L494 WHEEL - 19 INCH 5 SPLIT DOUBLE SPOKE ALLOY WHEEL STYLE 1 - GENUINE LAND ROVER
Is anyone here able to help out please? Many thanks in advance! Thumbs Up
Post #465866 24th Jan 2018 4:35pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
I can't see why they wouldn't.
But someone more qualified than me will - I'm sure - be along in a minute. What do I put here then?
Post #465879 24th Jan 2018 5:57pm
Sandyt
I know that there are only certain 19 that fit over certain brembo callipers on the l322 so guess that might be the only reason so if callipers are the same should fit
Post #465884 24th Jan 2018 6:36pm
CS
The 2015 brochure says "Only available on TDV6. Not available with 20"brakes." Only Range Rovers since 1988
Post #465970 25th Jan 2018 12:03pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Noticed that the 19” Style 1/5001 have appeared on the configurator for UK TDV6s (which have the smaller front discs), but they were listed as an accessory for all engines when the L405 was new (and came on HSE-spec cars elsewhere; some places had them as a no-cost option on the Vogue) - maybe another example of someone at LR not checking the details.
The L322 ended up with 380mm front discs under 19” wheels, and the L405 larger front discs are also 380mm - not sure if the calliper clearance is different.
Edit - just found a 2013 Australian spec sheet where it says the 19” are only suitable for the TDV6.
Post #465988 25th Jan 2018 2:51pm
Red Merle
Thanks for the replies Thumbs Up I’ve found the relevant pages in the 2017 MY brochure now Thumbs Up
Post #466003 25th Jan 2018 5:13pm
