Home > Maintenance & Mods (L322) > Debadging rear oval?
Danwilderspin
Has anyone removed this ? I can’t find much info - is it just glued on or are there some nasty posts going into the body? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #466082 26th Jan 2018 10:38am
georgedb
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Java Black
stuck on with double-sided tape.
Use a heat gun or hair dryer to heat up the glue and use floss tape to "cut off" the badge. Some tape residue might remain for which you'll have to use some liquid of sorts to remove
Post #466083 26th Jan 2018 10:50am
Vogue
Pull through the adhesive with dental floss and soak the adhesive in petrol for five minutes and rub off 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #466129 26th Jan 2018 2:42pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Carry on using heat on the residue to keep the tape soft and and removable.
I’ve never had luck with dental tape myself, personally finding an old credit card easier.
Post #466150 26th Jan 2018 5:16pm
verydisco
Works with a bazooka too (side effects may vary) Whistle Laughing l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #466160 26th Jan 2018 5:52pm
Paul thornton
Hammer and chisel would work I suppose!
I used a plastic trim removal tool and then some autoglym tar and glue remover.
Post #466171 26th Jan 2018 8:32pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I used boiling water then carefully pulled it off, replaced with new one from ebay exactly as OEM and fraction of the price.
Post #466198 26th Jan 2018 10:37pm
TimperleyRR
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
Some monofilament fishing line worked perfectly for me - no heating up required. Then a soft rubber disk I got from Powerful UK attaches to your drill and buffs off the tape residue without damaging the paint
Post #467343 4th Feb 2018 9:43pm
its easy when you know how Thumbs Up ... - .- -.
Post #467344 4th Feb 2018 9:46pm
p38arover
Australia
Why? Don't you want people to know you drive a Land Rover? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #467388 5th Feb 2018 8:44am
georgedb
The one I had faded and I replaced it with a new badge Wink
Some people on the other hand just like the "shaved" look Wink Wink Twisted Evil
Post #467452 5th Feb 2018 4:42pm
